Hi, I’m using Grafana 9.3.1 and configured alerts with Microsoft Teams, in test alert don¿t show hostname in URL like links, how to change the localhost wit hostname ?
Can you check and see the .ini file says
I try with this parameter “domain”
Hello, how do you connect the Grafana to the grafana labs? do you have tutorial?
