Changing root_url not changing the email links, still local host
grafana/latest
Grafana v12.0.0+security-01 (6475e5a4a4)
Get alert emails to have the right link
changed the root_url in the grafana.ini and respun container.
  • What happened?
when you click the link it takes you to local host
to go to the corect URL
Its not that complicated
No errors
How did you use that updated grafana.ini in the container?
Did you ever get this to work? I am having similar problem.
