Hi!
Is there a way to configure the link that we receive in the alerts templates in order to forward to its graph? I’ve been the option to change localhost to my domain so I want to go to the alert graph.
Thanks in advance!
Hi!
Thanks in advance!
you can set grafana servers ini setting root_url to the public facing url of your grafana, this is used when generating links in alert emails so the link will point to your grafana url
I want to configure my email alerts in such a way we can get the dashboard link to the alert itself. Any idea on how to do it?
Hi @shinydhas,
You can do this by editing your grafana.ini file and under the section named as [server]
There,
set the value for the config parameter root_url
to something like this e.g.
root_url = http://192.168.122.52:3000
Then, restart the grafana service and see the new alerts.
Once you click on the source button,
It will take you to the defined server instead of localhost.
Hope this helps.
