How to change/add dashboard auto refresh interval of 1s?
I already tried adding,
pi@pi5server:~ $ sudo cat /etc/grafana/grafana.ini | grep min_refresh_interval
;min_refresh_interval = 1s
However when I edit and the dashboard and add 1s to,
It just goes away immediate.
Any thoughts?
Thanks.
BTW expect a problems if your datasource can’t respond within second.
issue solved.
I had to take out ; from min_refresh_interval in grafana.ini
I adjusted Prometheus scrape_interval and evaluation_interval as well to 1s.
I know this could be CPU intenstive. But I will monitor CPU and temp and adjust accordingly.
