In the Synthetic Monitoring plugin, some of the graphs can be edited. When editing, I can see the query, so I can use the same query to reproduce the graph in my Grafana Dashboard.
For example, I can edit and check the query of the HTTP Latency graph
I know how to add a graph to the dashboard and get started. I’m asking how to get the data from Grafana Cloud to populate the Polystat graph (or any other graph that produces similar result, it could be squares or whatever) so it looks like the screenshot I posted.
This is the plugin I use:
install plugin on a local grafana instance
add some sites to check
click on “checks” tab and change display to “visualization view”
