I use Grafana 8.4.5 and I’m lost with new alerting system.
How have picture of the panel when I receveid mail or slack alert ?
Now I have only text, I want the picture of the panel in alerte.
Thanks for your help.
KG
KG
welcom to the
community @epoxsv!
Because the new alerts are created outside of the panel, it doesn’t include an image of the panel. You can use alerting templates to incorporate query values into your alert notification.
Hello Melori,
Thank you for your return.
Could you share me an sample of an alerte template for add this ?
KG
@epoxsv sure! you’ll find some alert template examples at the bottom of the page in the docs here: Message templating | Grafana Labs
