I am trying to understand a timechart/graph/time series chart in grafana.
If I create 3 tabs in browser(1 dashboard per tab)
1- 8th June, now-3d/d to now-3d/d in time picker, 93
2- 9th June, now-2d/d to now-2d/d in time picker, 100
3- 10th June, now-1d/d to now-1d/d in time picker, 4
Total adds to 197
then create another tab in browser with
All 3 days: 8th -10th June, now-3d/d to now-1d/d in time picker, 197, good and correct
but in the time series chart I get 4 values in the time chart which I presume is
2021-06-07-12:00:00 - 67
2021-06-08-12:00:00 - 126
2021-06-09-12:00:00 - 4
2021-06-10-12:00:00 - 0
Also the xaxis(time axis) is not per day format e.g. 7/6,8/6,9/6 (note time series is slightly better than graph for formatting the axis )
what I want in the time chart is
2021-06-08-12:00:00 - 93
2021-06-09-12:00:00 - 100
2021-06-10-12:00:00 - 4
I presuime this is a bucketing issue and/or time issue. Is there any way this cna be fixed? Or can I do anything to improve this? Or am i knitpicking?
Pictures below might illustrate it.
The values 67,126,4,0 should read 93,100,4 as per the correct time bucket
apologies, not sure why I wrote presume there, that is what I am seeing as I wrote in red in the pic.
my presumption might be that it is UTC time stamp issue.
did it really show 67,126,4,0 when you hover over it? → point by point?
Yes
what happened when you turn the visualization from graph to table?
not sure will double check, might be having trouble showing it in that format.
the values I get when I hover over inthe graph:
2021-06-08-12:00:00 - 26
for the 8th of June I just want to see one value in the graph. why am I getting 2?
i wish I could but not sure if possible. how can I investigate it at my end?
if I have only 3days selected, why is it showing 4 days?
Just checked moving the interval to hourly, I only get 3 days worth of data, and this data is as expected if I export the data and sum myself per day
the 8th
hmm, just revisting this, and trying to recreate in another example but I can’t seem to reproduce it, which is good, (but equally strange, so may revisit in future)
