Charts are not built for a time range other than the last 6 hours
I have a table machines_records_full in MySQL
describe machines_records_full;
describe
I’m trying to build a graph in Grafana for the last 6 hours:
SELECT
  time AS "time",
  lamp,
  tube
FROM machines_records_full
WHERE
  time BETWEEN FROM_UNIXTIME($__unixEpochFrom()) AND FROM_UNIXTIME($__unixEpochTo()) AND
  machine_id = 1
ORDER BY time;
Everything works well
But when I select a different time period, for example, for the last 15 minutes, the graph is not displayed
Although the request to MySQL returns data:
is your time column utc?
Indeed, I solved the problem using the time zone in the request in Grafana
SELECT
  CONVERT_TZ(time, '+03:00', '+00:00') AS "time",
  lamp,
  tube
WHERE
  machine_id = 1
GROUP BY time
ORDER BY time;
will that work for daylight savings time? +03:00 seems very static
Should it not be something like this?
convert_tz(time,'US/Eastern','UTC') and specifying your TZ
