How do i take screenshot without configuring image render into grafana.ini config file using curl command?
I have installed grafana into 1 VM and grafana image render plugin into other VM using docker container. i am looking for the way where without configuring image render into grafana.ini file as server_url and callback_url do we take screenshot?
presently i have configured plugin into grafana .ini file and it allow me to take screenshot but i am looking for way if without configuring plugin do we directly call render plugin and take a screenshot.
Appreciated on help in advance.
Thanks,
Suyash
HI can anyone suggest way to achieve.
Thanks,
Suyash
