I am trying to create a screenshot of a particular panel within my dashboard through grafana API. But i am not sure how to do that.
My Aim is to get the screenshot url through api and send the url to users.
Thanks
Thanks
This actually does not work very well. E.g. I tried to use python code to download screenshot and it downloaded just white stripe. Does anybody here have solution how to get screenshot from grafana using python or curl? (I would like this to work without GUI, selenium required GUI and it was the only one working program, but it just made a screenshot of login page… even though I used link generated when I use share button (pre-rendered image))
Here are several options what I’ve tried.
#!/usr/bin/python3
import imgkit
imgkit.from_url("http://192.XX.XX.XX:XXXX/render/dashboard-solo/db/new-dashboard?
orgId=1&from=1530528045287&to=1533120045287","out.png")
from selenium import webdriver
DRIVER = 'chromedriver'
driver = webdriver.Chrome(DRIVER)
driver.get('http://192.XX.XX.XX:XXXX/render/dashboard-solo/db/new-dashboard?orgId=1&panelId=3&from=1530528819708&to=1533120819708&width=1000&height=500&tz=UTC%2B02%
screenshot = driver.save_screenshot('my_screenshot.png')
driver.quit()
try:
from urllib.request import urlopen # py3
except ImportError:
from urllib2 import urlopen # py2
import json
url = 'http://192.XX.XX.XX:XXXX/render/dashboard-solo/db/new-dashboard?orgId=1&panelId=3&from=1530528819708&to=1533120819708&width=1000&height=500&tz=UTC%2B02%3A00'
response = urlopen(url)
data_str = response.read().decode()
data = json.loads(data_str)
print(data)
Ok, I figured this out.
curl 'http://<IP>:<PORT>/render/dashboard-solo/db/<DASHBOARD_NAME>?refresh=5m&orgId=1&panelId=<TAB_ID>&width=300&height=300&tz=UTC%202%3A00' -H 'Authorization: Bearer <API_KEY>' --compressed > OUTPUT.png
Before this you must generate API key in grafana settings
Hi is their a way where i can use the basic authentication without generating the API key for this feature.
Hey,
If you’re trying to send a screenshot link to users, Grafana doesn’t directly provide a public URL. It generates the screenshot as an image using its render API, but it doesn’t host that image for sharing.
A simple way to handle this is to first generate the panel screenshot using the Grafana render API. While looking at other options, you might find this screenshot APIs helpful, as it shows how some services handle both screenshot generation and hosting. After generating the image from Grafana, you can upload it to a storage service like S3, Cloudinary, or your own server. Once uploaded, you’ll get a public URL that you can easily share with your users.
I hope this will help ![]()
