What are you trying to achieve? We have three panels A,B,and C each come from difference sources and display independent counts over time. Paned D needs to display a total for all four different data sources and when panels A,B,C (either of them) does a refresh, that sum of A,B,C needs to update Panel D’s count.
How are you trying to achieve it? We do not know best practice for this so we inquire here.
What happened? Nothing yet.
What did you expect to happen? Nothing yet
Can you copy/paste the configuration(s) that you are having problems with? It is a simple count of rows of data from Influx for three panels A,B,C and we don’t know what to do to properly create Panel D.
Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were. No, there are no errors as Paneld A,B,C are all functioning properly and the attempt to create panel D has not been attempted. What is the best approach?
Did you follow any online instructions? If so, what is the URL? We found nothing related to this subject anywhere else.
