How do I change from points to lines (such as how Nagios shows its performance data)?
Hello
I apologize because I am very new to Grafana so this might be a basic question
Nagios shows its performance data as this:
My goal is to make Grafana show something similar or identical . For now, the “closest” Ive got is this:
Im pretty sure its possible to have both identical but I cant seem to do it.
Can someone help?
Thank you
To change from points to lines in performance data (like Nagios):
  1. PNP4Nagios: In the configuration file (pnp4nagios.cfg), set graph_type = line.
  2. NagiosGraph: Modify settings to use line graphs instead of point-based graphs.
  3. Grafana/Cacti: Select “Line” as the graph type in the respective graph creation interface.
These changes will ensure your data is visualized as continuous lines instead of discrete points.
I dont understand the reply…
Im trying to set the graphics type the same: Grafana to look like Nagios. I dont want to change anything in Nagios
Try:
I figured it out and forgot about this topic.
That was exactly it. Thank you
