How can I resolve a Grafana IRM incident with a summary through the API?
    Grafana Cloud IRM (SaaS; the exact build/version is managed by Grafana). Client OS and browser version have not been recorded.
    Resolve an incident and set its native resolution summary, as shown in Grafana or Slack—for example, “Resolved with Summary: …”. I want to set the incident’s resolution summary, not add a separate Key Update or timeline note.
    I’m using the Grafana Incident API with a service account token. The public API reference documents IncidentsService.UpdateStatus with incidentID and status. In the Grafana UI’s browser network calls, the resolve action appears to invoke a CloseIncident operation.
  • What happened?
    Calling UpdateStatus with status: "resolved" resolves the incident, but does not set its native summary. Creating a Key Update before calling UpdateStatus records the text separately; it does not produce the same result as resolving with a summary in the Grafana UI or Slack.
    I expected to resolve the incident and provide a summary in the same API operation, so the incident is recorded as resolved with that summary.
    This is the UpdateStatus request documented in the public API reference. Values are placeholders; no credentials are included.
    POST https://<stack>.grafana.net/api/plugins/grafana-irm-app/resources/api/v1/IncidentsService.UpdateStatus
    Content-Type: application/json
    Authorization: Bearer <redacted>
      "incidentID": "<incident-id>",
      "status": "resolved"
    The UI network call I observed is named CloseIncident; I have not confirmed its exact request body.
    No errors. The incident resolves successfully, but its native summary is not set through UpdateStatus.
    Grafana Incident API reference
    Configure Slack for Grafana IRM
    Could you clarify whether CloseIncident is a supported public API operation? If so, what endpoint and request body should be used to provide the resolution summary? Is there also a supported way to edit the summary after the incident has already been resolved?
The Incident API reference documents IncidentsService.UpdateStatus with only incidentID and status, which matches your request. Since there is no summary field in the request, it makes sense that the incident resolves without a resolution summary.
A Key Update is a separate timeline item, so it won’t populate the incident’s native summary.
Since the Grafana UI and Slack support resolving incidents with a summary, could someone from the Grafana team confirm whether CloseIncident is a supported public API operation and, if so, what request body it expects? If not, an optional summary parameter for UpdateStatus would be a useful feature request.
Could you also share the full response body from UpdateStatus? The response should include the updated incident object, which would help check whether the summary is returned.
