How can I provide data to geomap from prometheus?
This is my geo data to worldmap plugin.
Now I want to display the info in geomap. But I don’t know what data type geomap need. Is there an example for me to learn?
You should be able to use a Prometheus query for this data in your geomap panel. In it’s most basic form, you could just use geoip{} and set the Format to Table .
Then for the geomap panel properties, under Data Layer , set the Location to Auto, eg:
Thank you so much,It works.
It still have some problem.It’s very slow when I use geomap with worldmap style data.
And the dashboard has collapsed when i use Table and Auto.
Finally I switch the prometheus data as Instant,then it works well
