Hello Dears
i need a confluence report page to fetch data from grafana dashboard.is there any plugin connect them and i could share my graph on confluence page dynamically?
Hi @jalaltabatabaii,
Thanks for opening this post.
We do not have a direct solution which allows Grafana Dashboard to get integrated and display it in Confluence.
I found a v.close matching link and also this one too.
Making such integration needs some additional effort and this might not be available in the Grafana OSS version.
Might be but not 100% sure if such customization is available in the Grafana Enterprise version but still check here and ask the team if they might have such a possibility.
I hope this helps.
can you add iFrame in confluence?
