Are the documentation for V9.0 available yet?
Thank you
Thank you
I think this is all there is: What's new in Grafana v9.0 | Grafana documentation
Thank you I did see that
Wanted to see the changes around iFrame, if this is possible again. Only saw in the release about multiple image embedding.
That is with v7.0? from V8.0 it were not available. Or are there a workaround?
Are you using enterprise version? I am using OSS, I think that why you can iFrame
I am using OSS as well.
@grant2 Thanks but I am not sure why there is a difference then, I am running Open Source v8.4.6 and the embed option is not avalible.
My bad, I want to share the dashboard and not the panel, the panel you can iFrame
