grafana with docker(9.1.3) -
extract timeseries metric from logs and visualize it with dashboard. for example, extract Loss value(0.001811) from log string below
2022-09-08 22:46:31 Train Epoch: 14 [59520/60000 (99%)] Loss: 0.001811 -
create new dashboard, used log browser with query below
{filename=“/root/train/training/mnist/mnist_1.log”} | pattern<_> Loss: <loss>|label=loss -
What happened?
in dashboard, it indicates no data extracted with this query -
welcome to the
forum, @kmouleejunhyuk
I owuld check out this awesome dashboard on our public sandbox. It has some loki-based time series panels that might give you some clues:
https://play.grafana.org/d/T512JVH7z/loki-nginx-service-mesh-json-version?orgId=1
