Example I have following log data:
INFO | 2021-05-17 15:27:55.2544 | blah blah… tracked_unconnected=5 tracked_total=6345 diidabadiiaba
INFO | 2021-05-17 15:37:55.2544 | blah blah… tracked_unconnected=8 tracked_total=6345 diidabadiiaba
INFO | 2021-05-17 15:57:55.2544 | blah blah… tracked_unconnected=1 tracked_total=6345 diidabadiiaba
Now, getting this into Grafana as Stats panel to show last value, without! aggregation function as timeseries data… as tracked_unconnected “1” . with eg. TimeRange last 24hours.
This the closest working solution I got working:
quantile_over_time(
0.99,
{job=“TrackedTest”}
| logfmt
| unwrap tracked_unconnected
| error=""[1m]
) by (job)
This would require is a “raw” function (no aggregation). Like I want to have [0s] timeslice. Or then unwrap would work without aggregation function. I tried last_over_time function, but for some reason that is not recognized (using LOKI 2.2.1)
How you guys have been manage to pull out these type of things to Grafana via logs? is there a better way with LOKI.
