9.3.6 -
Plotting dashboard time series graph with data in below format.
55585:19785:31863
55364:19520:31720
54935:19337:31577
54786:19381:31434
54646:19278:31262
54266:19305:31137
54639:19515:31325
55488:19605:31676
54417:19223:31290
54596:19253:31408
53044:18725:30988
54438:19143:31477
55401:19475:31842
55167:19621:31545
55818:19720:31990 -
Log file is integrated through Loki and dashboard creation is being attempeted -
What happened?
Required timeseries trend for each counts separated by : delimiter is not visible -
Graph required as below
No issue with configurations -
No errors -
