How can I add a static labels to `kubernetes_sd_configs`?
I am using the recommended Promtail Kubernetes installation with this configuration:
I tried to add static labels like this, but it seems that it is not valid for kubernetes_sd_configs and it produces error:
    labels:
      log_app_source: k8
How can I add a static labels to kubernetes_sd_configs ?
I believe you are looking for static_labels, see static_labels | Grafana Loki documentation.
Thank you for help.
Do you know any working sample that incorporates kubernetes_sd_configs with static_labels by any chance?
