Hello There,
May I know if there are any ways to let Grafana not check the “Authorization” attribute in request header? Or if I can change the “Authorization” name to another one, like to “Authorization123”?
As far as I get from the tests, it seems even though I enabled the “Anonymous auth”; if your request contains the “Authorization” attribute in your request and the “Authorization”'s value is not empty, then Grafana backend seems that will still validate that…
I am testing with “grafana-7.2.2.linux-amd64.tar.gz”. Thanks a lot in advance.
