Hello there…
Just wanted to know if there are any ways to configure the Grafana’s request with custom header for the POST method? Because I want to let Grafana run on Cloud Platform, so there might be another security verifying on Cloud.
So, like, while I am adding a new Data Source on Grafana frontend, and then the frontend is calling the backend I would like to send another token within for those asynchronous requests. Therefore if there are any places where I can configure? Or only if I should change the Grafana’s codes?
Thanks for your advice…!
