API unauthorized 401
Hi, I’m trying to connect to grafana from a python script.
import requests
headers = {
    "Authorization": "Bearer XXXXXXXXXXXXXXXXXXXX"
url = "http://grafana.staged-by-discourse.com/api/dashboards/home"
r = requests.get(url, headers, verify=False)
print(r)
print(r.json())
And i always get message:
<Response [401]>
{‘message’: ‘Unauthorized’}
But if instead of runing the request in python i do curl, with the same token. I get the expected result.
I’ve been looking to other posts related to the API and the unauthorized message but I didn’t foun any solution
@ramondonadeucaballer if you increase your grafana server’s logging to debug, do you see anything interesting? I would also see if you can print any debugging info using the requests library in Python?
I would also include the exact curl command that you are using. Clearly there is some small detail off here…
Try
r = requests.get(url, headers=headers, verify=False)
headers is named argument
