I encountered an issue today with the Nginx service running as a container on our Ubuntu 20.04.6 LTS server. The service was in a stopped state, and I had to restart it manually.
I’ve attached a snippet from the syslog for reference. It appears that several services were restarted automatically, but Nginx failed to start.
2024/02/28 06:44:44 [notice] 1#1: signal 3 (SIGQUIT) received, shutting down
2024/02/28 06:44:44 [notice] 21#21: gracefully shutting down
2024/02/28 06:44:44 [notice] 21#21: exiting
2024/02/28 06:44:44 [notice] 1#1: signal 17 (SIGCHLD) received from 21
2024/02/28 06:44:44 [notice] 1#1: worker process 21 exited with code 0
2024/02/28 06:44:44 [notice] 1#1: exit
2024/02/28 06:44:47 [emerg] 1#1: host not found in upstream "grafana" in /etc/nginx/conf.d/grafana.conf:15
nginx: [emerg] host not found in upstream "grafana" in /etc/nginx/conf.d/grafana.conf:15
2024/02/28 06:44:48 [emerg] 1#1: host not found in upstream "grafana" in /etc/nginx/conf.d/grafana.conf:15
I have both Grafana and Nginx running as Docker images on my server, with Nginx serving as a reverse proxy. However, I faced a problem when the system stopped the Nginx service during daily cleanup activities. Unfortunately, the service failed to restart, and upon checking the Docker logs for Nginx, I found the above error. Upon further investigation, it seems that the upstream block is not present in our Nginx configuration file located at /etc/nginx/conf.d/grafana.conf . Currently, we only have “grafana” specified as the backend service.
- Is it necessary to add the upstream block in our Nginx configuration?
- How can we prevent similar errors from occurring in the future?
I appreciate your assistance in resolving this matter promptly.
Regards,
Alakananda S
