I followed documentation on how to configure NGINX to serve Grafana under sub-path. But I am facing 404 error.
nginx.conf
http {
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
upstream grafana {
server localhost:3000;
server {
location /grafana/ {
proxy_set_header Host $http_host;
proxy_pass http://grafana;
rewrite ^/grafana/(.*) /$1 break;
auth_basic "Restricted access";
auth_basic_user_file /etc/nginx/.htpasswd;
docker-compose.yml:
grafana:
image: grafana/grafana-enterprise
container_name: grafana
restart: unless-stopped
volumes:
- ./grafana.ini:/etc/grafana/grafana.ini
- ./datasources:/etc/grafana/provisioning/datasources
networks:
- proxyNetwork
grafana.ini:
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana
serve_from_sub_path = true
Now visiting http://localhost/grafana/ I get 404 error.
In the logs I get: [error] 22#22: *6 connect() failed (111: Connection refused) while connecting to upstream. How to make sure I can enter Grafana only via the provided link. Thanks.
Is nginx running in the container?
Yes, my Nginx running as the frontend container:
frontend:
image: frontend
container_name: frontend
ports:
- "80:80"
- "443:443"
depends_on:
- backend
volumes:
- ./nginx.conf:/etc/nginx/nginx.conf
- ./.htpasswd:/etc/nginx/.htpasswd
networks:
- proxyNetwork
Each container has own networking = also own “localhost”, so this is nginx’s localhost (where Grafana is not listening of course, because it is running in different container):
upstream grafana {
Point it to Grafana container:
upstream grafana {
server grafana:3000;
Read some Docker doc about networking for more details.
Yes, thank you, but now do I need this and exactly for what reason?
Because with this when I visit localhost/grafana I get redirected to localhost:3000/grafana and I get 404, since I do not expose the port in nginx config. WIthout this it works, but after i prompted to enter username/pass, it refreshes and asks again for credentials.
Configure root_url in Grafana config - url which is used to reach Nginx and
upstream grafana {
server grafana:3000/grafana/;
Hi, as I understood I had to change grafana root_url to
since this is where nginx is reached at or am I misunderstanding your comment? I get 404.
In logs I get “nginx: [emerg] invalid host in upstream "grafana:3000/grafana/" in /etc/nginx/nginx.conf:23” which points to:
Maybe you’ve got a working example somewhere?
I tried different ways via :%(http_port)s and :%(http_port)s/grafana, also doing as previously, but I get same error or it’s 404.
Update:
nginx.conf
upstream grafana {
server {
# auth_basic "Restricted access";
# auth_basic_user_file /etc/nginx/.htpasswd;
grafana.ini
root_url = %(protocol)s://%(domain)s/grafana
Uncommenting auth_basic asks for password, entering correct one refreshes the page and asks again - as it was discussed before.
I have the same problem with auth_basic. If you solve it, please let me know how.
