Hi i have a panel with query A and B, i would like the panel to only show query A or B dependent on a variable
anyone know how to achieve this?
can you please share what type of datasource do you have for these queries?
Hi Yosiasz,
I’m using PostgreSQL!
Here’s some more info on the queries:
Query A uses PostgreSQL’s LAG function to compare the timestamp of an error with the timestamp of the previous error that has the same error_code and product_id. If the time between the two errors is less than 40 seconds, they are grouped together.
Query B simply displays all errors filtered by product_id and error_code (set via variables), within the dashboard’s time range.
The idea is to create a data link from Query A that sets the variables for product_id and error_code, adjusts the dashboard time range (from the first to the last timestamp of the grouped errors), and then switches the panel to Query B.
Will Query A be displayed to the user in some sort of visualization (which one? table, time series) and when they click on visualization for Query A, Query B is filtered using values product_id and error_code from selected Query A “row” ?
At the moment both panels are table panels, i have a data link on the error code cell, clicking on the datalink in Query A will pass the entity_id and code to variables and put the dashboard timerange to: from start_epoch_ms to end_epoch_ms.
this way query B displayed the errors that are in the group you pressed in query A.
Groups errors if they occur within 30 minutes of each other using the LAG window function:
WITH cte1 AS (
SELECT
entity_id,
event_time,
code,
type,
description,
severity,
LAG(event_time) OVER (
PARTITION BY entity_id, code
ORDER BY event_time
) AS prev_event_time
FROM event_log_table
WHERE
severity IN ('critical', 'non_critical')
AND $__timeFilter(event_time)
AND entity_id = '$entity_id'
cte2 AS (
SELECT *,
CASE
WHEN prev_event_time IS NULL
OR event_time - prev_event_time > INTERVAL '40 seconds' THEN 1
ELSE 0
END AS new_group_flag
FROM cte1
cte3 AS (
SELECT *,
SUM(new_group_flag) OVER (
ORDER BY event_time
ROWS UNBOUNDED PRECEDING
) AS group_id
FROM cte2
SELECT
entity_id AS "Entity ID",
code AS "Code",
severity AS "Severity",
type AS "Type",
description AS "Description",
MIN(event_time) AS "First Occurrence",
MAX(event_time) AS "Last Occurrence",
EXTRACT(EPOCH FROM MIN(event_time)) * 1000 AS start_epoch_ms, -- time formatted for datalink
EXTRACT(EPOCH FROM MAX(event_time)) * 1000 AS end_epoch_ms, -- time formatted for datalink
MAX(event_time) - MIN(event_time) AS "Duration",
COUNT(*) AS "Number of Occurrences"
FROM cte3
GROUP BY
entity_id,
code,
type,
description,
severity,
group_id
ORDER BY "Last Occurrence" DESC;
Displays all errors filtered by variables and the dashboard’s time range:
SELECT
event_time AS "Error Timestamp",
code AS "Code",
type AS "Type",
WHERE
entity_id IN ($entity_id)
AND code IN ($code)
AND severity IN ($severity)
ORDER BY event_time DESC;
Any help on how to conditionally switch between these two queries would be greatly appreciated! i might be overcomplicating things, and i would love some feedback!
here is a hint for your data link, play with it
${product_id:queryparam}${__data.fields.product_id}
generates
in the datalink when you start typing $ you will start to see all kinds of treasures
