Changing panel query based on variable
I made a query that groups errors with the same error code based on the time between occurrences, right now i have a datalink send me to a different dashboard that shows all the errors in the group you pressed on by passing the error code and first and last occurrence as time range,
now my question..
i would like that pressing on the datalink would just change a couple variables in the same dashboard and change the panel with the grouped errors to a different “mode” that doesn’t group errors, so the datalink would pass error code:, time range: and mode:
i was just wondering if this was possible
