Hi dears,
i installed the new version 11.2.0 and i can’t find a way to disable the “Administration” menu item that is also visible for viewers.
Can anyone help me?
thanks
Hi Jan,
thanks for your answer, we too have RBAC configuration; we’ll try your configuration.
Thanks
Regards
Joao
then it’s there, because your
user has explore permission
No, that’s a feature.
just to avoid my possible misunderstanding: does your workaround hide the entire Administartion item and sub items, or only the “Correlations” item?
tnks
You can save your/my time just trying it on your end. A few clicks and you can check result.
i’m not able to enable Correlation toggle, and i see it on “Plugin and data” submenu of Administration (as admin user)
Doc is your friend:
If you don’t have the feature toggle management page, enable the
featureToggleAdminPagefeature toggle.
So lazy admin (like me) enables featureToggleAdminPage, so I can edit features via UI. But that’s not stopping you to use config file for any feature toggles (correlations included).
It works for me. So complain to your Grafana support (I did and they sorted 3/4 this kind of issues for now).
