Hidden panel on Dashboard
Panel is hidden, when I inspect element it’s panel 3
Added " &viewPanel=3 " to the URL and loads up blank page with Variables and Time Filter above, and got this error with F12
getPanelOptionsWithDefaults.ts:97 Uncaught (in promise) TypeError: Cannot read property ‘filter’ of undefined
at getPanelOptionsWithDefaults.ts:97
at Array.map ()
at s (getPanelOptionsWithDefaults.ts:96)
at getPanelOptionsWithDefaults.ts:76
at o (getPanelOptionsWithDefaults.ts:45)
at v.applyPluginOptionDefaults (PanelModel.ts:353)
at v.pluginLoaded (PanelModel.ts:375)
at actions.ts:139
Added edit panel and got these
at Array.map ()
at actions.ts:139
at Array.map ()
at actions.ts:139
at index.js:8
at Object.initDashboardPanel (redux.js:477)
Any help would be great,
Can delete the panel if needs just wondering if unreported bug,
Thanks :+1:
Hi @T_GrumpyEngineer :wave:
Are you saying that you’re editing the URL directly? Just want to make sure I’m understanding :blush:
Yes, When I open the Dashboard, there’s a blank space below, I found out it’s panel 3 and add that the the URL to load and i get into the blank panel same for edit
can you share your dashboard JSON?
I’ve rebuilt the panel and it’s fine, sorry for not replying
Will send privately if you think it may help with bugfixes but apart from that it’s solved by redoing.
