Grafana v8.2.5 (b57a137acd)
- What are you trying to achieve?
Connect InfluxDB Flux Database to Grafana
- How are you trying to achieve it?
url=http://192.168.50.6:8086
Auth is off
Organization=transmission
token=root:root //user:pass
- What happened?
Error reading InfluxDB.
Successfully connected to database.
- Can you copy/paste the configuration(s) that you are having problems with?
relevent InfluxDB config.yml
[http]
enabled = true
flux-enabled=true
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Grafana log when clicking the save and test button:
t=2021-11-29T07:09:09-0800 lvl=warn msg="Flux query failed" logger=tsdb.influx_flux err="403 Forbidden: Flux query service disabled. Verify flux-enabled=true in the [http] section of the InfluxDB config.\n" query=buckets()
- Did you follow any online instructions? If so, what is the URL?
Guide I am following is in the readme:
GitHub - cheeseandcereal/transmission_influxdb_exporter: Connects to transmission torrent daemon(s) and exports metrics to an influxdb instance
The exporter is successfully writing to the transmission database in flux to influxdb 1.8.4.
