Flux plugin in grafana
I am using Flux Plugin in Grafana, when querying the data , I a getting network forbidden error( 403)
I have updated http_enabled = true in influx.config file
Sounds like an error while authenticating. Have you made sure your username and password are correct?
Yep, I have double checked my username and password credentials.
Dear Madhur,
did you configure a Default Bucket like outlined below?
With kind regards,
Andreas.
Since, I am using InfluxDb_1.7 version, do I need to configure this?
Even after configuring this, i am getting the same issue
