Help on integrating the Grafana API into a monitoring system
We are developing a dam monitoring system and want to integrate Grafana as an application to graph the various sensor measurements. Some graphs are predefined, but we need other graphs that can be configured by the user, mainly the variables to be graphed, time range, different Y-axis scales, and graph type (bars, lines, etc.).
We have been testing integration via iframe but have not been able to provide the functionality we need.
We would like to know:
1. Is it possible to integrate Grafana into a Dashboard via API?
2. Is it possible to achieve these functionalities?
3. Could anyone help us with the API integration, if it is feasible?
Thanks for the comments and greetings!
