How do I get data in to my dashboard?
Im sorry, but its really hard to understand how to get data in yo Grafana/your dashboard in Grafana.
All I want to do is to push data, usage some api and create widgets/plugins based on that data.
Regards
Mikael
It sounds like you want to integrate against a custom API. You can use the Simple JSON datasource for that and create a wrapper api for the api:s/data you want to integrate it.
Please let me now if this helps you
Marcus
