Grafana 9.4.3 -
Generate a heatmap from Prometheus-style buckets captured by Telegraf into InfluxDB v1. -
Followed the documentation for heatmaps, but the Influx datasource does not offer the ‘Heatmap’ option in Format As dropdown.
Tried with and without the ‘non_negative_difference’ function. The values looked closer to what I would expect with the difference applied.
What happened?
Y-axis was not sorted by ‘le’ values.
I’ve not been able to determine if the data is correct, but the heat colour doesn’t look as if it is correct. -
Grafana to understand prometheus format cumulative buckets in the Heatmap panel. -
“type”: “heatmap”,
“title”: “Delivery Status”,
“gridPos”: {
“x”: 0,
“y”: 0,
“w”: 12,
“h”: 8
“id”: 46,
“targets”: [
“datasource”: {
“type”: “influxdb”,
“uid”: “PC61D9CAFA4D33E15”
“refId”: “A”,
“policy”: “default”,
“resultFormat”: “time_series”,
“orderByTime”: “ASC”,
“tags”: ,
“groupBy”: [
“type”: “time”,
“params”: [
“$__interval”
“type”: “tag”,
“params”: [
“le”
“type”: “fill”,
“params”: [
“null”
“select”: [
“type”: “field”,
“params”: [
“DFM_Delivery_DeliveryStatusProcessorCamel_bucket”
“type”: “last”,
“params”:
“type”: “non_negative_difference”,
“params”:
“measurement”: “tomcat.prometheus”,
“alias”: “Status $tag_le”
“fieldConfig”: {
“defaults”: {
“custom”: {
“scaleDistribution”: {
“type”: “linear”
“hideFrom”: {
“tooltip”: false,
“viz”: false,
“legend”: false
“overrides”:
“datasource”: {
“uid”: “PC61D9CAFA4D33E15”,
“type”: “influxdb”
“pluginVersion”: “9.4.3”,
“options”: {
“calculate”: false,
“yAxis”: {
“axisPlacement”: “left”,
“reverse”: false
“rowsFrame”: {
“layout”: “auto”
“color”: {
“mode”: “scheme”,
“fill”: “dark-orange”,
“scale”: “exponential”,
“exponent”: 0.5,
“scheme”: “Oranges”,
“steps”: 64,
“reverse”: false
“cellGap”: 1,
“filterValues”: {
“le”: 1e-9
“tooltip”: {
“show”: true,
“yHistogram”: false
“legend”: {
“show”: true
“exemplars”: {
“color”: “rgba(255,0,255,0.7)”
No errors -
Attempted to follow instructions at How to visualize Prometheus histograms in Grafana | Grafana Labs
