Grafana v9.0.1 (14e988bd22) Windows 10 21H1 -
I’m trying to monitoring hosting providers network and compare which location is more stable to my ISP. -
Using Blackbox-exporter and Prometheus record TCP & ICMP jobs and use the “probe_duration_seconds” metrics to generate a heatmap. -
What happened?
The heatmap perform well in each field, but it sort alphabetically by the label name I assigned in legend. -
I want to know is there any possible to sort the each field by some query likeSum over time
orAvg over time
to make result similar like this
Slightly change this tutorial Replacing Smokeping with Prometheus - anarcat
