Hi, I’ve deployed an application (Graphite) and I’m sending Pre-bucketed data to Grafana and trying to create a heat map with this data.
To do so, I followed the docs available at http://docs.grafana.org/features/panels/heatmap/
The data seem to be displayed as expected with one problem: The buckets are order alphabetically and numerically. The heat map should order the buckets in the Y-axis from smallest at the bottom to largest.
Is it possible to do this? Is there any configuration that I’m missing?
The images explaining my heat map:
Axes Configuration:
I’m using Grafana v5.2.2
