I need to create horizontal lines representing min and max values for a selected period on a time-series panel. The data source is Prometheus.
At the moment I end up with 3 queries like so
Metric:
sum by(process) (windows_process_working_set_bytes{process="MyProcess"})
Max
max_over_time(sum by(process) (windows_process_working_set_bytes{process="MyProcess"})[${__range}:])
Min
min_over_time(sum by(process) (windows_process_working_set_bytes{process="MyProcess"})[${__range}:])
But it does produce a sort of floating graph of max and min values calculated from out of selected time rather than horizontal lines sitting on the peak and the bottom of metric graph.
Grafana v12.2.1
