Plot some rows of timeseries depending on condition
Will update later to add this info, using Prometheus datasource
I have a metric “my_metric”, with a name and value. It can be 0 or 1. I want to plot max(my_metric) by (name), but only for "name"s which have had a 1 for at least one hour continuously at some point in the dashboard range.
I tried multiple things, but the closest I got was with query max(my_metric) by (name) on (name) (min_over_time(my_metric[1h]))
  • What happened?
However this graphs the result of min_over_time(my_metric[1h]), not the result of max(my_metric) by (name)…
No errors
Create dashboard variable, which will have only names with that condition and then use that variable in the panel to filter only timeseries with those names.
