We are using Grafana 9.4.3 -
I am trying to graph the power factor measured by a power meter. -
I set up a Time Series panel using the following query:
from(bucket: "SCADA")
|> filter(fn: (r) => r["_measurement"] == "${Substation}")
|> filter(fn: (r) => r["point_id"] =~ /Power/ or r["point_id"] =~ /kW/)
|> filter(fn: (r) => r["_field"] == "CV")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
|> yield(name: "last")
I put the kW and kVAR measurements on the left axis and the power factor on the right axis, formatted as a percentage with a soft min of -100% and a soft max of 100%.
What happened?
The power factor in the green trace is varying between +99.9% and -99.9%. See below for why this is a problem. -
Power factor actually runs from -0% to 100% to +0%, with +/- 100% being in the middle and =/- 0% being at the ends, rather than having zero in the middle. Is there a way to achieve this with Grafana’s time series panel? -
No -
I didn’t find any instructions, but I did find a unanswered related post in the plugin development section of the community: Power factor measurement Gauge
Any help or guidance here would be much appreciated.
