Hello I have a graph with the KWh consumption, this data is from a influxdb, and I’m using Grafana 5.4.2. This is the data (right axis)
I would like the graph to start on the zero, according to the rage selected. I tried
SELECT min("kwh") - "kwh" FROM "power" WHERE ("deviceId" = 'main') AND $timeFilter GROUP BY time($__interval);
No luck!!!
Also I would like to create a bar graph that would show me the daily kwh consumption. I can’t seem to find a way to do this!
SELECT max("kwh") - min("kwh") FROM ( SELECT "kwh" FROM "power" WHERE $timeFilter ) GROUP BY time("1d")
No luck!
Can any one help me? Is this possible with the data that I have in the DB?
thank you
