Grafana with DeepInstinct - Possible?
Dear Community
I am a new Grafana-User and have not found any information about my request. We are using the Antivirus-Tool DeepInstinct. Does anyone have experience with the connection to Grafana? Is it possible and can I find a tutorial for that?
Thank you all.
Welcome
Does deepinstinct provide a rest api endpoint ?
Does it provide access to its backend?
Hi
I think yes. I can create API for example to connect by Anaconda and more.
Then maybe you can use infinity plugin to make a call to the api
Can you share a data structure sample of what the api would return?
