Grafana Windows node Monitor
Hello All,
I am currently using Granfana for monitoring my windows node servers.
The challenge I am facing with the dashboards is unable to build multiple servers on a single dashboard
i.e : Server 1, Server 2 & Server3 of respective IP : 172.xx.xx.xx , 172.yy.yy.yy & 172.zz.zz.zz
I want all three windows hosts to be monitored on a single dashboard
If yes its possible please help me out the steps & config of the dashboard.
Regards
Girish Bharadwaj
It should definitely be possible to have them on one dashboard and even in one graph panel.
What database are you using? Prometheus or something else?
