Grafana Version Upgrade
Current Grafana version - 8.5, running on RHEL server.
I want to upgrade the Grafana version to latest version.
Can I directly upgrade Grafana to latest version without going to version 9,10 or etc.
Yes, you can.
make sure to back your grafana db (sqlite or otherwise before you do that) before you do what @anilyadav recommends
