4.0.1 -
upgrade to v9.4 -
Not sure how to do this -
What happened?
N/A -
N/A -
N/A -
N/A -
No
I would go with one version upgrade at a time. What operating system is this deployed in?
wow 4.0.1? Was that pre-beta grafana?
Are you using sqlite back end or something else?
JFYI
There is a technology stack changed somewhere starting from version as the Frontend started to use Typescript and Backend is on GoLang
It will be expected that with other minor problems/issues you will also notice warnings and errors that Dashboard is not supported etc and the reason is above ![]()
I would very highly recommend to perform the upgrade on a dev machine instead on the production one and create all the backup for both the database and also your Dashboards with each incremental update (as @yosiasz already suggested).
This way you which was the last version and where things totally cannot go forward.
Good luck with the upgrade ![]()
