Current version of our grafana application is v6.7.1 (ca6d08d5cb) -
Upgrade to latest version -
upgrade the version -
What happened?
Need the documetation for upgrading -
welcome to the
community @balajiselliappan
I’d recommend reviewing the release notes and changelog so you know what changes have happened since Grafana 6.7.1. You’ll also want to back up the database that grafana uses and plugins in case you want to roll back.
The upgrade guide walks through how to back up the database:
