Grafana v 11.2.2 login loop
After the update to V 11.2.2 I get the endless login loop after brief ‘Login Success’ notice. Does anybody else face the same issue? Any hints how to resolve this? Many thanks and Cheers, Falk
I am having the same problem and am searching for a solution.
Good to know that I’m not the only one … Tried meanwhile everything proposed for similar issues occurred earlier. Nothing worked so far. I did un-install Grafana and will wait for a proper solution. Not sure whether I’ll re-installl at all
I had the same issue. Cleaning all cookies from Grafana helped.
In my case, I’ve cleared all browser data and even tried using different computers (windows and mac) that have never been used to connect to Grafana before. For some reason I can currently only login from one browser (Safari) on one computer and I have no idea why.
I may have found a solution/workaround:
In grafana.ini, change “cookie_samesite = none” → “cookie_samesite = disabled”
I remember having this issue many years ago and I found some online guidance to add “cookie_samesite = none”. It seems something about that setting was causing this most recent login loop. After changing the setting as shown above, I am now able to login from all of my browsers again (for now).
