grans
March 16, 2021, 8:26am
1
After everything worked properly (7.4.3), I can no longer log in with Chrome / Windows10 or Edge / Windows10. After entering username and password, the green popup “Logged in” appears, but immediately afterwards I am logged out. Cleaning the cache, clearing history or adjusting the cookie settings does not matter. Even after disabling all browser extensions no succes.
When I log in with Firefox on the same PC, everything goes smoothly. Everything also works fine on my Android tablet with Chrome.
Is this a known issue? I couldn’t find anything in the forum, can someone help me?
grans
March 16, 2021, 9:03am
2
I did some more searching and found in grafana.ini the line “cookie_samesite = none” which would be necessary because I want to embed in an iframe. If I mark this line with a semicolon I can log in with Chrome and Edge so this is the cause.
Can anyone tell me how to set “cookie_samesite” so that I can use iframes and still login with Chrome?
Please provide reproducible example. It’s not clear how is your grafana configured, which domain is used, errors from browser console… Provide details, logs, errors, how did you debugged issue,. … to increase your chance for answer.
Blind guess: wrong Grafana configuration which makes invorrect cookies (secure cookie, cookie domain, same site attribute,…) which are not accepted by browsers.
grans
March 16, 2021, 9:07am
4
Thanks for your reply! While you were responding I was also typing, please read what I wrote about grafana.ini.
So still looking for a solution.
Again, you are not posting your full Grafana config (just single line instead of everything) if you want proper answer. Go and read how Chrome (The newest Edge is also Chrome based) handle samesite cookie config. Random blogpost WTF is Chrome’s SameSite cookie update? - Digiday Blind guess (because your Grafana config is secret, so I really don’t know if it your case):
Any cookie with the “SameSite=None” label must also have a secure flag, meaning it will only be created and sent through requests made over HTTPs.
grans
March 16, 2021, 11:54am
6
There is nothing mysterious about my setup info and it is certainly not secret. I didn’t want to bore readers with such a large file, but now that you explicitly ask for it, I’ll post it:
DEFAULT
app_mode production
instance_name PH-Grafana
alerting
concurrent_render_limit 5
enabled true
error_or_timeout alerting
evaluation_timeout_seconds 30
execute_alerts true
max_annotation_age
max_annotations_to_keep 0
max_attempts 3
min_interval_seconds 1
nodata_or_nullvalues no_data
notification_timeout_seconds 30
analytics
check_for_updates true
google_analytics_ua_id
google_tag_manager_id
reporting_distributor grafana-labs
reporting_enabled true
annotations.api
max_age
annotations.dashboard
max_age
auth
api_key_max_seconds_to_live -1
disable_login_form false
disable_signout_menu false
login_cookie_name grafana_session
login_maximum_inactive_lifetime_days
login_maximum_inactive_lifetime_duration 7d
login_maximum_lifetime_days
login_maximum_lifetime_duration 30d
oauth_auto_login false
oauth_state_cookie_max_age 600
signout_redirect_url
sigv4_auth_enabled false
token_rotation_interval_minutes 10
auth.anonymous
enabled true
hide_version false
org_name LW
org_role Viewer
auth.azuread
allow_sign_up true
allowed_domains
allowed_groups
api_url
auth_url https://login.microsoftonline.com/<tenant-id>/oauth2/v2.0/authorize
client_id some_client_id
client_secret ************
email_attribute_name
email_attribute_path
enabled false
hosted_domain
name Azure AD
role_attribute_path
scopes openid email profile
tls_client_ca
tls_client_cert
tls_client_key
tls_skip_verify_insecure
token_url https://login.microsoftonline.com/<tenant-id>/oauth2/v2.0/token
auth.basic
enabled true
auth.generic_oauth
allow_sign_up true
allowed_domains
allowed_organizations
api_url
auth_url
client_id some_id
email_attribute_name email:primary
enabled false
hosted_domain
id_token_attribute_name
login_attribute_path
name OAuth
name_attribute_path
role_attribute_path
scopes user:email
team_ids
tls_client_ca
tls_client_cert
tls_client_key
tls_skip_verify_insecure false
token_url
auth.github
allow_sign_up true
allowed_domains
api_url https://api.github.com/user
auth_url https://github.com/login/oauth/authorize
client_id some_id
enabled false
hosted_domain
name github
role_attribute_path
scopes user:email,read:org
team_ids
tls_client_ca
tls_client_cert
tls_client_key
token_url https://github.com/login/oauth/access_token
auth.gitlab
allow_sign_up true
allowed_domains
allowed_groups
api_url https://gitlab.com/api/v4
auth_url https://gitlab.com/oauth/authorize
client_id some_id
enabled false
hosted_domain
name gitlab
role_attribute_path
scopes api
tls_client_ca
tls_client_cert
tls_client_key
token_url https://gitlab.com/oauth/token
auth.google
allow_sign_up true
allowed_domains
api_url https://www.googleapis.com/oauth2/v1/userinfo
auth_url https://accounts.google.com/o/oauth2/auth
enabled false
hosted_domain
name google
role_attribute_path
scopes https://www.googleapis.com/auth/userinfo.profile https://www.googleapis.com/auth/userinfo.email
tls_client_ca
tls_client_cert
tls_client_key
token_url https://accounts.google.com/o/oauth2/token
auth.grafana_com
allow_sign_up true
allowed_domains
api_url
auth_url
client_id some_id
enabled false
hosted_domain
name grafana_com
role_attribute_path
scopes user:email
tls_client_ca
tls_client_cert
tls_client_key
token_url
auth.grafananet
allow_sign_up true
allowed_domains
api_url
auth_url
client_id some_id
enabled false
hosted_domain
name grafananet
role_attribute_path
scopes user:email
tls_client_ca
tls_client_cert
tls_client_key
token_url
auth.ldap
active_sync_enabled true
allow_sign_up true
config_file /etc/grafana/ldap.toml
enabled false
sync_cron 0 0 1 * * *
auth.okta
allow_sign_up true
allowed_domains
allowed_groups
api_url https://<tenant-id>.okta.com/oauth2/v1/userinfo
auth_url https://<tenant-id>.okta.com/oauth2/v1/authorize
client_id some_id
enabled false
hosted_domain
name Okta
role_attribute_path
scopes openid profile email groups
tls_client_ca
tls_client_cert
tls_client_key
token_url https://<tenant-id>.okta.com/oauth2/v1/token
auth.proxy
auto_sign_up true
enable_login_token false
enabled false
header_name X-WEBAUTH-USER
header_property username
headers
ldap_sync_ttl 60
sync_ttl 60
whitelist
auth.saml
enabled false
single_logout false
dashboards
default_home_dashboard_path
min_refresh_interval 5s
versions_to_keep 20
database
ca_cert_path
cache_mode private
client_cert_path
client_key_path
conn_max_lifetime 14400
connection_string
host 127.0.0.1:3306
log_queries false
max_idle_conn 2
max_open_conn 0
name grafana
password ************
path grafana.db
server_cert_name
skip_migrations
ssl_mode disable
type sqlite3
url
user root
dataproxy
expect_continue_timeout_seconds 1
idle_conn_timeout_seconds 90
keep_alive_seconds 30
logging false
max_idle_connections 100
send_user_header false
timeout 30
tls_handshake_timeout_seconds 10
datasources
datasource_limit 5000
date_formats
date_format_use_browser_locale false
default_timezone browser
full_date YYYY-MM-DD HH:mm:ss
interval_day MM/DD
interval_hour MM/DD HH:mm
interval_minute HH:mm
interval_month YYYY-MM
interval_second HH:mm:ss
interval_year YYYY
emails
templates_pattern emails/*.html
welcome_email_on_sign_up false
enterprise
license_path /var/lib/grafana/license.jwt
explore
enabled true
expressions
enabled true
external_image_storage
provider
external_image_storage.azure_blob
account_key
account_name
container_name
external_image_storage.gcs
bucket
enable_signed_urls false
key_file
path
signed_url_expiration
external_image_storage.local
external_image_storage.s3
access_key
bucket
bucket_url
endpoint
path
path_style_access
region
secret_key ************
external_image_storage.webdav
public_url
url
username
feature_toggles
enable
grafana_com
url https://grafana.com
grafana_net
log
filters
level info
mode console file
log.console
format console
level info
log.file
daily_rotate true
file_name /var/log/grafana/grafana.log
format text
level info
log_rotate true
max_days 7
max_lines 1000000
max_size_shift 28
log.frontend
custom_endpoint /log
enabled false
log_endpoint_burst_limit 15
log_endpoint_requests_per_second_limit 3
sample_rate 1.0
sentry_dsn
log.syslog
address
facility
format text
level
network
tag
metrics
basic_auth_password ************
basic_auth_username
disable_total_stats false
enabled true
interval_seconds 10
metrics.environment_info
metrics.graphite
address
prefix prod.grafana.%(instance_name)s.
panels
disable_sanitize_html false
enable_alpha false
paths
data /var/lib/grafana
logs /var/log/grafana
plugins /var/lib/grafana/plugins
provisioning /etc/grafana/provisioning
temp_data_lifetime 24h
plugin.grafana-image-renderer
grpc_host
grpc_port
rendering_args
rendering_chrome_bin
rendering_clustering_max_concurrency
rendering_clustering_mode
rendering_dumpio
rendering_ignore_https_errors
rendering_language
rendering_mode
rendering_timezone
rendering_verbose_logging
rendering_viewport_device_scale_factor
rendering_viewport_max_device_scale_factor
rendering_viewport_max_height
rendering_viewport_max_width
plugins
allow_loading_unsigned_plugins
app_tls_skip_verify_insecure false
enable_alpha false
marketplace_url https://grafana.com/grafana/plugins/
quota
enabled false
global_api_key -1
global_dashboard -1
global_data_source -1
global_org -1
global_session -1
global_user -1
org_api_key 10
org_dashboard 100
org_data_source 10
org_user 10
user_org 10
remote_cache
connstr
type database
rendering
callback_url
concurrent_render_request_limit 30
server_url
security
admin_password ************
admin_user admin
allow_embedding true
content_security_policy false
content_security_policy_template script-src 'unsafe-eval' 'strict-dynamic' $NONCE;object-src 'none';font-src 'self';style-src 'self' 'unsafe-inline';img-src 'self' data:;base-uri 'self';connect-src 'self' grafana.com;manifest-src 'self';media-src 'none';form-action 'self';
cookie_samesite lax
cookie_secure false
data_source_proxy_whitelist
disable_brute_force_login_protection false
disable_gravatar false
disable_initial_admin_creation false
strict_transport_security false
strict_transport_security_max_age_seconds 86400
strict_transport_security_preload false
strict_transport_security_subdomains false
x_content_type_options true
x_xss_protection true
server
cdn_url
cert_file
cert_key
domain localhost
enable_gzip false
enforce_domain false
http_addr 0.0.0.0
http_port 3000
protocol http
root_url %(protocol)s://%(domain)s:%(http_port)s/
router_logging false
serve_from_sub_path false
socket /tmp/grafana.sock
static_root_path public
smtp
cert_file
ehlo_identity
enabled false
from_address admin@grafana.localhost
from_name Grafana
host localhost:25
key_file
skip_verify false
startTLS_policy
user
snapshots
external_enabled true
external_snapshot_name Publish to snapshot.raintank.io
external_snapshot_url https://snapshots-origin.raintank.io
public_mode false
snapshot_remove_expired true
tracing.jaeger
address
always_included_tag
disable_shared_zipkin_spans false
sampler_param 1
sampler_type const
sampling_server_url
zipkin_propagation false
users
allow_org_create false
allow_sign_up false
auto_assign_org true
auto_assign_org_id 1
auto_assign_org_role Viewer
default_theme dark
editors_can_admin false
external_manage_info
external_manage_link_name
external_manage_link_url
hidden_users
login_hint email or username
password_hint ************
user_invite_max_lifetime_duration 24h
verify_email_enabled false
viewers_can_edit false
+1 for conf file markdown formatting, -10 that conf section are not readable and that looks like a default config - a lot of default rubbish lines, which are obviously not used (it looks like you really want to waste my time )
You are not using secure cookie, so that’s a problem for SameSite=None in the chrome:
That’s one obvious issue. Please don’t expect that cookie_samesite = none and cookie_secure = false solve the problem. Highlighting: “it will only be created and sent through requests made over HTTPs”. So make proper secure setup: proper HTTPS and proper cookie config and it will be working fine.
