I want to embed my grafana instance in an iframe and login to grafana via there.
I have succesfully embedded grafana into my webpage, but when I login succesfully, it just takes me straight back to an empty login page.
Also I don’t want to enable anonymous access because you can then just visite my grafana instance and access all dashbaords without logging in.
Does anybody know a solution?
Can you try this:
Set to true to enable embedding Grafana dashboards in iframes
allow_embedding = true
[http]
Set to true to allow the browser to send and receive cookies from the iframe
cookie_samesite = true
[auth]
Enable cookie authentication
login_cookie_name = grafana_session
login_maximum_inactive_lifetime_days = 7
login_maximum_lifetime_days = 30
disable_login_form = false
Doesn’t work, but we came to a new solution for our use case.
@vijha1989
true is not a valid value for cookie_samesite, see documentation.
@maximbozek2002
Care to share what you did to solve it?
