Grafana iframe login page stuck on loop
i’ve implemented Grafana as an iframe integration and i successfully seeing the login screen.
but after successfully login the login page is loaded again and i cannot see the dashboard or any other path
both of the machines are running at AWS services (grafana as standalone and web interface as standalone - not on the same machine)
Please advice :slight_smile:
Sorry for reviving this old topic but I was having the same issue and was having trouble finding the solution. What worked for me personally, was going into the grafana.ini (or defaults.ini) and changing the following configurations:
  • allow_embedding = true
  • cookie_secure = true
  • cookie_samesite = none
In the event that someone else get this error in the future, this solution may be helpful.
Thanks @xiaonuno . I had also faced the same issue. This solution fixed it
hi i tried this fix but i get the error “failed to determine the state of the sso redirect”
