Hi people,
Anybody knows if there is a simple way to create a timeline panel like this one in Grafana?
I reviewed available options in Grafana, and in Apache ECharts (using Volkov Apache ECharts Plugins for example), but I didn´t find any suitable alternative.
I don’t understand much about development, but for example here, there is a simple example did on JS (the one of the image above):
Any ideas? Anyone tried to did something similar? Maybe is a good idea for a Volkov Labs Panel Plugin @mikhailvolkov ,
Thanks in advance.
Regards,
Alejandro
Have you looked at the new canvas plugin as a possible solution?
Hi @yosiasz,
Nope. Do you think that Canvas plugin can be an option for this?
I’m going to review that plugin and try to construct a timeline with it.
Thanks.
Regards,
Alejandro
@yosiasz ,
I think the problem with Canvas to create something like a timeline, is that the objects and their location on Canvas plugin are static, and I need that the timeline “populates” in order with all the calendar dates and description lines of every date. Do you think that there is a way to create that with Canvas plugin?
Thanks.
Regards,
Alejandro
